The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3316 Questions View all
Can I replace home button but not the touch id?
I have iphone 5s but suddenly the home button does not work! Suddenly I didn't do anything I just got it out from my pocket and it wasn't working! the touch id works fine but the home button doesn't!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I'm afraid as soon as you replace the button you lose the touch id. Maybe start buy taking it apart and seeing if there is a reason that's visible for the home button to stop working . Sometimes dirt and grime can get in and gum up the works . Try cleaning with IP alcohol . Check connectors and re-seat them to make sure there together ok. Hope this helps
Score 2
Add a comment
Add your answer
RationTrack will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 62
