Heating and tumbling, but not drying? Frigidaire GLEQCAS2 Dryer
Hey there,
So my dryer is no longer drying my clothes... well it will eventually after 2-3 cycles. It is heating. It is tumbling. We took it apart and cleaned all the dirt and lint from inside of it. The hose is not kinked or clogged. There is airflow to the vent outside... I dont know what it could be?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Most Frequent Causes for Dryer takes too long
Cause 1
Air Flow Problem
If the vent is clogged or partially clogged, it will restrict the airflow through the dryer, substantially increasing the drying time. To ensure proper dryer performance, you should clean your dryer’s venting system at least once per year.
Cause 2
Heating Element
The heating element warms the air before the air enters the dryer drum. If the heating element is burned out, or if any other part of the assembly is defective, the dryer may not heat. To determine if the heating element is at fault, use a multimeter to test it for continuity. If the heating element does not have continuity, replace it.
Cause 3
Lint Filter
The lint filter might be clogged. Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the lint filter is clogged, clean it.
On my dryer, it has two heating elements and one was operating. The other has a break in the heating coil. I replaced that and the thermal fuse.
Gleqcas2 is a partial model number for a Frigidaire Dryer. To see specific parts for your Dryer, please choose your exact model from the list below or choose the model that’s closest.
Frigidaire Dryer Model GLEQ2152EE0
Frigidaire Dryer Model GLEQ2152EE1
Frigidaire Dryer Model GLEQ2152ES0
Frigidaire Dryer Model GLEQ2152ES1
Frigidaire Dryer Model GLEQ2170KE0
Frigidaire Dryer Model GLEQ2170KS0
Frigidaire Dryer Model GLEQ221AS2
Frigidaire Dryer Model GLEQ332AS0
Frigidaire Dryer Model GLEQ332AS1
Frigidaire Dryer Model GLEQ332AS2
Frigidaire Dryer Model GLEQ442CES0
Frigidaire Dryer Model GLEQ642AS0
Frigidaire Dryer Model GLEQ642AS1
Frigidaire Dryer Model GLEQ642AS2
Frigidaire Dryer Model GLEQ942CS0
Score 2
Add a comment
Add your answer
kirstenellison will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 42
All Time: 147
