Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
91 Questions View all
Can you help with the name of coaxial cable?
The coaxial cable it is located under the camera that conect antena with the motherboard . I broke i don't know the name to buy it .
Update (07/15/2016)
Ipad mini A 1490 ....................................
Comments:
It is round with a pin inside and it connect female-male .
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
The ZIF connector next to the camera is actually the proximity sensor connector. The top right antenna assembly is the primary TX/RX antenna for cellular services(connecting to the top right coax connector) and doubles as a proximity sensor(the ZIF connector next to the main camera). The top left antenna(coax connector under the front camera) is for cellular diversity RX and GPS.
The prox sensor is not used for any user activity, it's just for RF compliance. Leaving it damaged does affect you using it in any way. The parts for cellular iPads are hard to source so I would say just leave it there.
Score 3
Add a comment
Most Helpful Answer
Is this the part you're looking at?
iPad Mini 2 LTE Wi-Fi/Bluetooth Antenna Replacement
Score 3
Comments:
Sorry but it is not the cable that i want . This is the cable that i want is like this : https://www.google.al/url?sa=i&rct=j&q=&...
. I bought one from ebay but it was smaller . Now i want the name to be
by
It seems like this but i colud not find it . I bought an iphone coaxial cable but it was smaller .
by
Is is not the wifi/bluetooth antenna. It is round female that connect with the male .
by
Add a comment
sashen141 since your iPad is a A1490 it is not a LTE. It is a mini 2 WiFi&cellular. Here is the part and you can find the guides for the repair on here
iPad mini & mini 2 Wi-Fi/Bluetooth Antenna Image
Score 2
Comments:
@oldturkey03 - Thanks, I missed the fact that sashen had selected the wrong machine icon.
by
I thought they are the same. iPad mini 2 only has one cellular variant, working on all cellular technologies.
There is a "A1491" variant but that's only sold in China, adding TD-LTE but cuts CDMA.
by
A1489 on the iPad mini 2 Wi-Fi
A1490 on the iPad mini 2 Wi-Fi + Cellular
A1491 on the iPad mini 2 Wi-Fi + Cellular (TD-LTE)–released early 2014
by
The "wifi + cellular" is the "wifi + LTE" model, Apple changed the name only because when iPad 3 was released with "LTE" in the model name, an Australian customer sued Apple because the device did not support Australian LTE bands but Apple still calls them "LTE". Apple then changed the names to avoid confusion.
by
Add a comment
Add your answer
sashen141 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 173
