Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Questions View all
iPhone 5s not starting or charging, tried new battery no difference
Hi a friend of mine told me if i can have a look into his iphone 5s, the phone have had a cracked screen but was working and just before he gave it to me died and it never turned on again.
I have tried re starting, dfu, disconnect the battery, i have tested the voltage of the battery and it was 0v, I replaced the battery for a new one no change whatsoever.
It could be the motherboard?
Add a comment
1 Answer
Chosen Solution
Hi, more than likely Tristar/U2 IC chip issue, if a cheap cable has been used this is more than likely your problem, and requires micro soldering.
No power with new battery could be PMIC (power management)
Score 1
3 Comments:
The thing is that the phone doesn't start with a fully charged battery either, is that normal with the ic chip fried?
by
Not usually no, could be PMIC
by
If the phone does not turn on with a known working good fully charged battery then it's probably not the charging IC and is more like the power management ic.
by
Add a comment
Add your answer
raulfrago will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 102
