New Hd, no wifi icon, can't finish updates.
I installed a new Hard Drive in my iMac 21.5 desktop, then used the original install DVDs successfully. There is no wifi icon to hook it up and in system preferences and clicking on network I can find no way to set up wifi. Also when I try to do updates, it Downloads them but won't restart to install them. When I look up system updates like Yosemite they have black lines through them and I can't even down load them.
Help!!!
Comments:
We need to know your exact machine. You can look that up using the serial number from the bottom of the stand. and plug it in here: http://www.everymac.com/ultimate-mac-loo...
Also the make and model number of the old and new hard drives.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I called apple and they helped me do a disc image download of snow leopard. Then using the App Store they had me download El Capitan.
It took a while but it installed perfectly. The only issue I have now is the wifi is missing and I cannot find it when I go to system network then to network. This is a 7 year old computer. Apple helped me for free. They said since it was a problem updating system they would help. They helped me for 2 hrs. They are knowledgeable and patient. Go Apple support.
Score 1
Comments:
I installed a new airport card. This did not help. So I bought a USB wifi connection. This was good solution. It was easy and worked right away. It took longer to open the package it came in than to plug it in to the computer .
by
Add a comment
Most Helpful Answer
Still need to know your exact model to get you to the correct guide. Sounds like you used a hard wire connection to do the download. Go under the Apple to about this Mac > System Report > WiFi and see if the Wi-Fi card is even being seen.
Score 1
Add a comment
Add your answer
Deleted will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 118
