iPhone 6 Battery Draining while phone is off.
Hello, I am having an issue with my iPhone 6 Battery and am looking for some help. After replacing the battery and the charging port my battery appears to be draining while the phone is turned off. I will go to sleep with battery at 100% and turned off (holding the power button and sliding my finger across to turn it off not just standby) and I will wake up in the morning and the phone will not turn on and will require charging again. Anyone have this problem before or a similar problem?
3 Comments
When using it, how long does the battery last?
by Gigabit87898
the other night i used it for about 4 hours watching hulu and it drained from 100% to around 50% its not a phone we actively use in the house as we have replaced it and mainly only use it for apps now.
by Thomas Hurta
Why are forums the place to ask irrelevant questions? How fast it drains in use won't help diagnose problem. There is clearly a short in a circuit. Question is how to test when the phone is off? I don't know. I would look for a conductor between battery & case & I believe most likely would be moisture. Just a guess.
by fm Haynie
