Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
nut on logic board came off
Hi,
while taking out the screen of my iPhone 5 for a screen replacement, this nut for the one 1.2mm Phillips Screw came off the logic board (I still have it):
http://picpaste.com/DIsaXjsiLvlOTMRx.hug...
Anyone has a suggestion on how to fix it? Or if it actually matters, if it's missing?
Thanks a lot!!
Add a comment
Chosen Solution
You don't need that screw hole if you have the other two screws for the metal lcd cover plate. Just make sure you do not use the demagnetized one on the two lower screw holes instead of the top one. Putting the demagnetized screw in the wrong screw hole can damage the logic board.
Score 3
1 Comment:
ok thanks a lot!
by
Add a comment
Mine came off too, don't worry, no problem.
Honestly I used to not even keep my cover plate on.. found it too annoying to put back since the fit was so tight.. every time I tried, the digitiser would snap off and I'd have to keep reseating it.
I've left my plate off for the majority of my phone's use and the phone works fine.. so you can either just do the bottom two screws and let the plate have some movement, or just not use the plate at all.
Right now, I have the plate on, connected by the bottom two screws (had to do a earpiece replace), still works fine.
It'd need a real good knock for any of the ribbons to drop out of place.
But yes, just be careful, the screw holes have some critical logic board sections beneath them.. I guess that's how Apple catches you if you put in the wrong screw.
The particular piece you've lost / snapped off is certainly not needed.
Score 1
Add a comment
Add your answer
tillhunger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 138
