HD action camera with touchscreen LCD, released October 5, 2014.
87 Questions View all
Should I replace Motherboard?
Hi all,
My camera is not charging or responding to anything, either plugged in into a wall charger or laptop ect.
Background:
I believe I damaged the motherboard by charging it with a crap usb charger (output of 5.35V). It smells a bit like burnt electronics and it heats up if I connect it to the power. Even with no battery, the camera does not respond. I have tried other batteries so that is not the issue. I have tried other cables and is not the issue either.
The camera is out or warranty and GoPro support wont even try to look at it :(
The Question:
I believe that the charging circuit/voltage regulator is part of the Motherboard. However, I am afraid that this would not solve my problem (ie. may have damaged other parts of the camera). I am an Electronics Engineer and I am able to replace the board.
Just wondering if someone has done it before or had similar issues??? I do not have a schematic to diagnose the fault so it is a risk if I decide to replace the motherboard and it does not work....
Thanks for taking the time to read this
Cheers
Add a comment
Chosen Solution
Here's the guide on replacing the logic board: GoPro Hero4 Silver Motherboard Replacement
Here's the part: GoPro Hero4 Silver Motherboard
GoPro Hero4 Silver Motherboard Image
Product
$54.99
Score 2
Add a comment
Hi guys,
I have a similar problem. I did purchase a new mobo and followed the replacement guide to no avail. My Silver still won't turn on.
Do you guys have any idea what else could be the problem?
Add a comment
Add your answer
Novice RC will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 577
