Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
4035 Questions View all
My touch screen does not work after digitizer/screen replacement.
Water damaged iphone. Rice for 48 hours. Everything works but touch screen (receives phone calls, texts, etc., touch sensor works). Replaced screen/digitizer. Still doesn't work. What else can I try?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Probably one of 2 IC chip may have problems. On the back of the pcb below the black tape there are 2 IC
located over the Large Metallic chip your PMIC in this case. Above the PMIC you have your Mason IC and your Cumulus both those IC controls touch and display to your phone. If you are not experiencing any zebra lines than most likely the mason chip is bad the black chip over the small metallic BCM chip the on the back to the left of the board the number on it will start with 343S. The only way to repair is to replace the bad IC. This is something that take special tools and knowledge to repair. Search your area for a shop that performs this type of repair. Another possibility is that the screen it self may have gone bad due to the water damage.
Although you have a display the tough on the screen may have gone bad. This is an advance issue and needs some one with a little knowledge to diagnose the correct problem.
Comments:
thank you. I will try to find somewhere that can perform this.
by
Add a comment
Add your answer
C Erikson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 71
