do not have alive
My phone was dead , and has revived its time when it died , I tried to use power but it hung at 0,1A . please help me
Try a known good charged iPhone 5s battery and if it turns on try charging via USB cable while on.
If no charge try another charger port.
If new charger port no work then charging IC chip / component issue.
If phone no turn on at all then maybe power ic at fault.
I would like to thank you for your help . But I 'm sorry , I switched n ic power but still lifeless . Somehow please help me , I 'm stuck
dear friend
i had read your question, and i am understanding the issue that you removed battery then connected power source on board, then you see the source showing high current,
so just understand that,
the current showing high because of short circuit on the board, normally the short circuit happening on mother board due to faulty ic, normally power management ic, so replace the power management ic, (i hope it will fix your issue).
good luck my friend.
you saying already had replaced power management ic.. after replacing power management ic it still shows the same?
if it shows the same you should do check the + and ground is shorted by using multi-meter
if have short you need to work on board ...
it's very strange . sometimes it has life , but sometimes it's dead . I have never met such
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 105
5 Comments
@hoang51195 some of this seems to get lost in translation. give us a more descriptive idea of what happened. I am interested in this " power but it hung at 0,1A". What do you mean by that?
by oldturkey03
i am Vietnamese. I'm not good at english. I must rely on the help of google .
my iphone seems n dead . I used the fire source and it hung at 0,1A . Please try to understand and help me . I hope from you
by hoang
@hoang51195 where did you connect the power to? Start with the suggestion by Ben and try a new battery.
by oldturkey03
I tried a new battery but n remains inactive
by hoang
by hoang
