Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1958 Questions View all
Battery Will Not Charge.
My iphone was charging fine, after i changed headphone assembly and put back together it will not charge from the outlet charger or from connected to computer.also it gets very warm when you hold the phone.
Add a comment
1 Answer
Chosen Solution
check dock connector and also battery contacts are clean and connected properly. there is a screw that pushes battery onto motherboard check this is in correctly (near don't remove sticker)
Score 2
Add a comment
Add your answer
lloyd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,156
