Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
265 Questions View all
Vertical Lines appears on the screen/retina display
My ipad mini 2 has vertical lines appearing on the screen and after i lock and unlock my device it dissappears. My ipad has not yet been dropped ever since. Thankyou
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Most likely you have a bad lcd. I would try replacing the lcd under the screen...this should fix the issue.
If your device was dropped this is most likely the issue. If not try restoring it first just in case it's a software bug.
Add a comment
Add your answer
Carlo Fajardo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 182
