Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
iPhone 4 with iPhone 4s lcd
I understand they are the same connectors so it will work but does anyone have any tips on how to adjust the metal border pieces so they sit in the same spot the iPhone 4 lcd has them
Add a comment
Most Helpful Answer
@kenji here is a quote from Is the display the same for the 4 and 4s? "The connectors are the same for the digitizer and LCD and the screen will function properly between the models but the parts are physically different and will not fit either way." Read some more about it Front digitizer+lcd unit and the back panel compatible with iPhone 4S? and iPhone 4 screen assembly v iPhone 4s. Right now I am saying that it will not fit, unless heavily modified. you'll have a much higher success rate if you replace it with the right display.
Score 1
Add a comment
Well, he's right. It would be best to get the correct part. I've modified several of those display assemblies, to fit the current model phone. I just tear off the brackets on the side and use adhesive to hold it to the frame. You can use superglue, but I find it looks bad
I use this
[linked product missing or disabled: IF145-283-2]
Score 1
Add a comment
Add your answer
Kenji will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 98
