Support for gas-powered and electric golf cart, sometimes referred to as golf cars, or club cars after the Club Car Golf Cart brand.
258 Questions View all
The shoes don't contact the drum.
I put new shoes on 91 Club Car, adjusted as much as possible but the shoes don't contact the drum. When I activate the brake lever at the bottom of drum only the rear shoe expands but not enough to contact drum. The front shoe remains stationary. How is it supposed to work?
This cart belongs to a friend and he said he hasn't had brakes for a few months. Never parks on hill and never follows to close. I looked at the shoes and they were almost to metal so I put some new shoes on. Still won't stop. I adjusted the upper adjuster all the way in (towards backing plate) and never got the shoes to contact drum. I adjusted the cable equalizer to make sure there was enough slack to completely release the lower lever the cable is attached to, but made sure it still fully activated the lever for maximum shoe expansion. When I fully engage the lower lever the shoe towards the rear of the wheel moves but only about 1/8" the front show doesn't move at all. It seems something is not right in that lower shoe expansion set up but it doesn't appear to be broken. Thanks for any help.
Score 1
Add a comment
Chosen Solution
@ezgoer since you did not tell us how you adjusted your brakes, lets start there so we are on the same page. Also, it may be of benefit if you post a couple pictures of your brakes assembly with your question. That will allow us to see what you see. Use this guide for that.
Score 2
Comments:
your brake cylinder must have contacted with water and has been rust inside that why the brake shoes are not moving far apart.
by
Add a comment
Most Helpful Answer
Start with this answer from old turkey @oldturkey03 and hope he chimes in on this question: looking for a diagram for Club Car Golf Cart rear brakes
Here's a video on how to install them: https://www.youtube.com/watch?v=isl2-uLw...
Here's a video on how to adjust them: http://blazerbites.blogspot.com/2006/08/...
Score 2
Add a comment
Add your answer
Bob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 225
