F20 comes on after rinse cycle
Washer stops and reads F20 on screen
You could have a siphon problem through your drain hose. Make sure that the drain hose is properly installed. Check to see if the end of the hose is stuck way down the stand pipe. If it is, then the hose will need to be pulled out. Only about 6" to 8" should protrude down the stand pipe.
Here the answer on the F20 code: http://www.fixya.com/support/r1491905-f2...
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 3,598
