Won't working after the fall
So,my iPhone 6 is not working after fall
I've tried things like:Long charging(it just gets hotter),Hard reset,Dfu and so on...
iTunes can't recognize it too
What could it be?
What could it be?
Wondering if it's your battery. Try disconnecting, then reconnecting your battery
I second iMedic: possibly the battery. My iPhone 6 had major damage (run over), but it was working for several hours before it died. During the several hours it was getting very hot, though. (Towards the middle and bottom of the phone.) After I replaced the battery (and the front panel of course because it was smithereens) it worked fine.
Also, replacement batteries on Amazon are pretty cheap and it's an easy fix, so you can at least rule that out before worrying about things that are more expensive/complicated.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 108
2 Comments
Most likely a component chip got damaged after drop. It's a common issue where one of the power management chips get damaged from shock caused from dropping the phone.
Not sure exactly which one. It gets hot at the upper part of the phone right below the rear camera?
by Ben
Which side of the phone it fall on
Cause if he phone is getting hot when charging a lot which it means no batter or power issue I reset it down at work means no storage or other issue
I guess it is a displacement of a certain thing from phone
by Sara Khan
