Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
394 Questions View all
Blown DisplayPort fuse - where to get?
Hi!
I just opened up my iMac 27 and put it back together. When I fired it up I heard a little "pop". Opening it up again, I can see a fuse (?) has melted near by the DP power port:
I might have been clumsy and put the cable the wrong way, making the fuse pop.
It seems like it should be replacable with a decent soldering iron. But what fuse is it and where do I buy it?
Thank you in advance
Add a comment
1 Answer
Chosen Solution
ulflundqvist not a fuse but an inductor. That is reference designator L9000 which is a 250 oHm inductor used as a filter. The schematic does not reference the inductance so you will have to do some checking around mouser.com or digikey as well as others.
Score 2
Comments:
Order those caps too C9020, C9001 in case they are bad , make sure you order 2 or 3 of each including inductor in in case they fly of the board while your working, then you'll have to wait for more shipping these parts will be relatively inexpensive.
by
Totally agree with John on that one
by
Hard to say but it might just work. Nothing to lose at this point
by
Add a comment
Add your answer
ulflundqvist will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 277
