data recovery after water damage
i have a iPhone 6 which was water damaged. Im hoping for data recovery, i took all emi shields and cleaned corrosion away. BY using schematic i found the speaker ic was causing problem and removed that, now i have a problem with capacitors around the baseband chip and also 'c1417' which i believe is to do with charging, if i was to remove this to try shorting would it affect the charger port so the phone wouldn't turn on? i have photos for you to see board and damaged components
I hope you can help.
1 Comment
Please do not shorten out any components. this can make your situation worse. If you know the component is faulty, replace it with a proper one.
by oldturkey03
