Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Questions View all
Trying to repair a 5s - Running into issues with diagnostics
Hello, I am trying to repair a 5s for a customer.
The phone does not turn on They have been to an iphone repair facility previously who mentioned that it needed a u2 replacement
My diagnostics attempt.
* The battery was dead,
* I charged the battery and connected the 4 terminals as shown in the picture and the battery
* I pressed the power button for about 30 seconds
* The phone did not turn on and became very hot and 2 generic locations on the board
Is there any other way I can diagnose the board or make the iphone turn on ?
Thanks
Image Link http://i.imgur.com/l0D97dQ.jpg
Score 1
Add a comment
1 Answer
Most Helpful Answer
What you're describing is a U2 (Tristar) chip issue. If you replaced the charging port and put in a good battery and the phone doesn't turn on or charge then the U2 chip needs to be replaced which is underneath the shielding were it gets very hot that you mentioned in your picture. It requires a skilled person that knows microsoldering to replace the chip. I hope this helps you answer your question.
Score 2
2 Comments:
I read somewhere that the bad U2 prevents the phone from charging.
Will it also prevent the phone from turning on when connected to a charged battery ?
by
Yes. I just got a iPhone 6 that the customer stated would not turn on or charge. Checked charging port it was good. Checked battery and it was bad, But after replacing the battery it would intermittently charge at times and the battery quickly died. Replaced the U2 chip and now the phone is working perfectly with new battery.
by
Add a comment
Add your answer
g2k3 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 100
