Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
168 Questions View all
Damaged Wifi Antenae?
Hi
I am in the process of replacing my cracked front panel. In removing the old panel I think I may have damaged the wifi antenae. I have torn it where it screws to the frame , everything else is intact . I've tested to see if still picking up wifi and it does . So, will this be ok or will I have issues later on?
Thanks
Add a comment
1 Answer
Chosen Solution
That part is very cheap and easy to replace. If you have the iPad already open, better to change it out now than a week later after you put the screen down and now start having wifi issues. And as luck will have it you will break the screen later when you take the screen off to now fix that wifi issues
Comments:
Thanks for reply. I guess I will replace it. I just wanted to know if tearing it where it attaches to the case would be an issue?
by
Add a comment
Add your answer
ian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 49
