Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
449 Questions View all
Question about replacing iPad Air 2 front glass screen.
Hi folks,
I dropped and shattered the glass screen on my iPad Air 2 but the touch LED beneath is perfectly fine and working.
I have read comments that replacing the glass front alone is murder because it's practically fused to the LED display beneath and trying to separate them can very easily result in wrecking the LED completely.
Is this true? Should I not bother with trying to replace and fix just the glass and replace the entire LED+Glass assembly instead?
Thank you.
Score 3
2 Comments
Not sure if this is the same model but I have the A1475 model and replacing the front glass only was a total breeze. Literally took 30 mins, no digitiser fusing or anything like that. I didn’t even have to use a heat gun.
by
In fact you are confusing it with the original iPad Air, which has the LCD piece and the digitizer/glass screen NOT fused together.
The iPad Air 2 model number is A1566 (Wifi) and A1567 (Cellular)
by
Add a comment
Chosen Solution
That is 100% correct. The digitizer and LCD are fused together to create a single unit, and separating them to do a glass-only replacement requires an LCD separator machine, polarizer scraper, and some additional equipment and OCA to refuse the new glass. Additionally, this procedure will be fairly difficult considering the size of the display. So, unfortunately, your best bet is to replace the assembly as a whole.
Score 5
9 Comments:
Thank You Evan that's as I suspected. I'm surprised there are apparently so many people even attempting this repair and claiming to have success using a piece of chewing gum and a tea spoon in their bedrooms.
Any suggestions a to the best place online to buy this 'whole assembly' please for an iPad Air 2?
by
That's interesting. I've seen some creative techniques for doing glass-only repairs on iPhones with varying degrees of success, but I can't imagine any homebrew approach would be effective with a screen that big. We carry iPad Air 2 assemblies in our store if you want to pick one up.
by
Yes Iv'e done iphones myself but that's a different and much easier story :) Thanks for the link.
by
Ok so removing broken one is kind of straight forwards accroding to this..
iPad Air 2 Wi-Fi Display Assembly Replacement
But odd there is no guide on fitting the replacement.. in particular the micro soldering involved. I wonder why? Too difficult maybe.
by
I'm not sure what you mean by fitting the replacement, but you should be able to follow that guide to replace the screen as it is. If you're referring to the micro soldered part on the back of the display to the left of the home button, the displays we currently sell do not have that part, but we haven't been able to identify its purpose. Maybe you can shed some light on it?
by
Show 4 more comments
Add a comment
iPad air (first version) is separate from the LCD SCREEN and is easy to change, the air 2 is a different story though
Score 2
Add a comment
@ irevive - I'm def interested, and plan on doing the repair myself. What other supplies will i need - anything that's staring me not in the face? I've seen clashing advice on what's needed.
I have the micro screwdrivers, guitar picks, priers and such. Any adhesives needed?
1 Comment:
Yes, you will need some sort of adhesive strip for the closing of the device, I used the red tape sold in the ifixit store as it works well for me with other devices as well.
by
Add a comment
Add your answer
Chi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 53
All Time: 28,379
