The Dyson AM07 is a bladeless tower fan released in 2014. The AM07 uses "Air Multiplier" technology to create a smooth stream of air without using visible blades.
19 Questions View all
Fan is not turning on - have tried different outlets, no luck.
Have plugged fan into different outlets, changed remote battery - nothing. Is there a fuse that can be replaced and if so where do I purchase and how do I replace it?
Score 2
Add a comment
1 Answer
There is one timed fuse on the main PCB, but if the fan is not powering up at all, and you can hear a very faint noise coming from the base (high pitched whistling noise), then the problem may very well be the main PCB. The chip on it has a tendency to break down if the fan is not cleaned out regularly and the main plug top fuse is up rated.
Add a comment
Add your answer
corgimom48 will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 20
All Time: 1,705
