2005 Hyundai Santa Fe Wont start.
I have a 05 santa fe with the 2.7L engine that won't start. I bought it this way. Was told that car died and was towed home. Found that alternator was bad. While they were replacing alternator they sparked the ratchet against the block.
Symptoms: cranks but no start.
Checked fuel pressure. Good. (Also tried a little starting fluid still no go)
Noid light tested injectors: good
Spark tested the coil pack. Good.
Tested all relays and fuses. Good.
Pulled ecu to check for moistened or shorts .. No noticeable signs.
Pulled the top cover of timing belt loose to verify belt didn't snap.
Next thinking about pulling all covers to check timing marks...
Any other suggestions?
3 Comments
I have a 2004 Hyundai Santa Fe 3500 V6 cranks over but will not start I was low on gas out of gas to it and it's still not starting
by Jon Arends
And it ran just fine yesterday until I shut it off
by Jon Arends
i was driving and the power steering belt broke , and now it cranks but it wont start , i have a v-6 3500 , i checked the timing belt and it's not broke .????? it acts like it isn't getting spark. what can i do ?
by Jason M Andrews
