Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
I fixed the water damage but...
i fixed the water damage, though now the iphone will only turn on when plugged into the wall, and when it does turn on it can't get any signal, GPS,WIFI, BLUETOOTH,or cell, nothing works. then it reboots every few mins.
Score -1
Add a comment
Chosen Solution
Have you replaced any parts.. When you say fixed water damage?you have cleaned motherboard with alcohol? Then it sounds like possibly dock connector for signal problem +/- charging prob. Battery and dock are usually fried in phones I have repaired.
Score 3
Add a comment
Sounds like there is still water inside causing a short.
Add a comment
tommy
probably bad battery also.
Add a comment
Add your answer
cesar8635 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 863
