2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Upgrade RAM & HD MackBook Pro A1260
Hello:
I need to know if i really can upgrade the RAM to my MacBook Pro until 6 GB, 'cuz when i check in www.apleeserialnumberinfo.com the information said than maximum RAM is 4 GB.
In addition I want to know if the 750 GB 5400 RPM Western Digital SATA Hard Drive (New) @ $119.95 works in my MacBook Pro or is better install the 640 GB 5400 RPM Western Digital SATA Hard Drive (New)
Thanx and best regards from Venezuela
Score -1
Add a comment
1 Answer
Chosen Solution
Your best bet would be to download Mactracker (it's free), and see the "actual" max of your machine. The actual max is usually higher than Apple's recommended max. For instance; Apple has my machine's max at 4GB, but my actual max is 6, which means my machine will see and utilize 6 GB of RAM. As far as the HD is concerned, it's a matter of preference. It depends on wether you need the storage or not. If speed is what you want, then I would opt for a 7200RPM drive. If you want more storage, than any of the drives you mentioned would suit you just fine. As long as the drive is 2.5" and 9MM in dimensions, it would fit your Mac. Good Luck.
Score 4
2 Comments:
+ good
by
Add a comment
Add your answer
marcelmarcano will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,437
