Cant identify flex cable component
I have been doing a research project to identify a small flex cable component with no luck. I looked at the SMD code index and brought in all available samples starting with 13(X) but none have worked. They have all arrived on the smaller end of the specs so I know they aren't the right one. The component we have says "13E". No other characters. The engineer I am working with cannot provide information and I have reached out to multiple companies to see if I can send them a sample with little response. We have paid for R&D help in the past our last identification project was around $700.
These are the components that were not successful.
SMD Code Package Device Name Manufacturer Data
13 • SOT-23 MTP3413N3 CYStech P-Channel MOSFET
13 SOT-23 MMBD1503 Fairchild Diodes
138 SOT-323 BSS138W Fairchild N-Channel MOSFET
13W SOT-23 BSS84 NXP P-Channel MOSFET
13 SOT-23 ZD13-AE3 UTC Zener diode
13** SOT-23 MTP3415KN3 CYStech P-Channel MOSFET
13A SOT-346 PZM13NB2A Philips (Now NXP) Zener diodes
13 _ SOT-23 APR3013-29-AI-TRL Anpec Voltage Regulator
I need help identifying or a recommendation for a research organization we can send samples to. the pdf attachment has the original measurements listed on the yellow post it.
Error-107_Upper-Flex-Component-_13E_-R&D.PDF
Add a comment
