Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1066 Questions View all
How to recover my data from iPhone 6s?
Hi, I accidentally dropped my iPhone 6s onto the ground and now the screen is scattered and unresponsive. There are some important data including contacts that I desperately want to recover on my iPhone. Is there a way to retrieve the data on my iPhone?
Comments:
Usually , the iPhone data is not easily deleted , timely scan data from iPhone ,or from the backup to recover them ,maybe these data will be back:
https://www.mobiledic.com/ios-topics/rec...
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Hi Cass, you can recover your data on your iPhone. Here are two ways at your disposal:
1.If you have a backup in iTunes or iCloud, you can restore the data from the iTunes/iCloud backup. However, the backup will replace the data on your iPhone and the new data generated since you last sync will be wiped.
2.If you don’t have a backup. You can use Jihosoft iPhone Data Recovery. I have tried it after I smashed my iPhone 6 accidentally last month. It helped recover all my data from the smashed iPhone. And It allows you to retrieve data from your device directly or from iTunes backup. They have both Window version and Mac Version.
Score 1
Comments:
Thank you Arlene. I don't have a backup. I think I must recover directly from my iPhone. I am using a Mac, so i should download the mac version?
by
Yes, you're welcomed.
by
Add a comment
Most Helpful Answer
Hi Cass,
Does your phone sync to iTunes when you plug it into your laptop? If it does, then you can do a backup for you to move onto another device potentially.
Cheers, Chris
Score 1
Add a comment
DO NOT DOWNLOAD ANY "RECOVERY SOFTEARE" RECOMMENDED BY ANYONE FROM ANYWHERE. THEY ARE ALL LOWLIFE SCAMMERS.
If the phone has been synced with iTunes, you can sync it again at anytime, since the PC has the backup keybag for the instance of iOS on your phone, so you can load any data. If you have iCloud enabled, the contacts are already synced with iCloud, and your data contents are backed up daily over wifi when you plug in to charge. So you can just buy a new phone and download them back.
If you don't have any of the backups mentioned above, you WILL need to repair your phone to load data from it. Usually this involves replacing the display and if necessary, reballing and replacing the touch ICs.
Any recovery software is worse than useless in this situation.
Score 1
Add a comment
Try to find them in your backup first.
Add a comment
First check if there is a backup on iTunes, if yes, you can easily recover from iTunes backup files. If no, maybe you can try a iOS Data Rescuer tool. With its help, you can get access to data on a broken screen iPhone 6S and extract data from it.
Add a comment
Add your answer
Cass will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 271
