Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor
154 Questions View all
Sluggish performance across the board
So I work for an Apple repair shop and am well versed in most hardware/software troubleshooting. The #1 problem people have when they come in is a slow iMac/Macbook that freezes and beach-balls (colorful spinning icon). We always check the RAM and CPU usage to see if theres a rouge application that is chewing up memory, but that almost never seems to be the case. We clear out extensions in browsers, run anti-virus to clear out malware, check he HD to make sure its not loaded to the brim, but usually to no avail. We are tired of being unable to help our customers with what should be an easy repair. Is there any solution to a perpetually slow Mac other than the steps listed above? We tend to see the kernal (root) task running anywhere between 50-130 threads on exceptionally slow Macs. Please help with this overly persistent issue.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Depending on the series of the system you can see different causes.
With either an HD or SSD based system free space is a big issue!
  • HD's the issue becomes a more fragmented disk so the OS & App need to work harder to find free space (this also pushes the systems hardware as well). I recommend having 1/4 of the disk free. I also recommend defrag'ing the drive at least once a year. Before doing an OS upgrade I clean things up and then after doing the upgrade I often find I need to defrag the drive.
  • SSD's also need free space but unlike a HD they don't need defrag'ing. Drive size is a big problem with SSD's they tend to be too small for most people. Here the need of free space is in fact larger! Often I try to achieve 1/3 free on the smaller sized drives as the disk is also used for virtual RAM and these smaller drives systems also tend to have less RAM (8 GB) so the need of the space is more important.
With both running disk utility from an external boot drive to repair file permissions and drink issues is a common action item as well as clearing out the old cache & log files as they to build up over time.
Hardware failure!
  • Using the wrong HD during an upgrade can be an issue. Make sure the systems SATA port I/O speed is listed within the new drives spec sheet. Often I find a fixed SATA III drive put into a system that can't support it.
  • Make sure the systems firmware is up to date
  • The older MacBook Pro's SATA cables have issues either the rev is not able to support the new drive or the cable is damaged.
  • Fusion Drives can get messy, the drive is failing or changed out can create strange performance issues.
OS & Apps can also be a cause!
  • After upgrading a drive after a restore from a backup you do need to give the system sometime to re-index the files. So the size of the backup can have a cause and effect here. You would see the indexer using most of the process threads.
  • Making sure the OS and Apps are at the latest can be a good start. But, there have been times when the app was updated automatically when we hadn't updated the OS yet causing problems as the developer did not test things in the older OS as thoroughly as they did on the current OS.
Score 3
Add a comment
Most Helpful Answer
I generally drop in a Seagate SSHD. In my opinion it doubles the perceived speed of the machine. Be aware that the 2009-2012 models used Apple proprietary heat sensor firmware in the hard drives. Some will need OWCs in-line thermal sensors. Others just the correct stock heat sensors. There were different sensors for Seagate, Western Digital and Hitachi. If you don't you may encounter run-away fans.
Score 3
Add a comment
Add your answer
Matt Carlin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 87
