The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying.
913 Questions View all
logic board will not put solder on pins
So i was trying to put new fpc in the logic board it wouldn't drop into the solder than i tried making the solder smooth and it looks like i took the pin off and now it won't have solder in some areas. Any idea how i can fix this myself?
Update (07/01/2016)
any ideas
Comments:
use solder braid, clean up the area . add flux then reapply your solder
by
a picture is worth a thousand words but it sounds like you may have torn a pad off of it. Using solder braid might aggravate this situation but you need to clean up the other pads to have something to solder to. Flux is your friend and don't touch that FPC connector with an iron or it'll melt something close to instantly.
For help with a damaged pad, find ipad rehab's video about doing these type repairs.
by
don't know what to do?
by
Add a comment
1 Answer
Chosen Solution
Here's a video on repair the fps on your iPad 2. Look through it and compare your parts to see if there are complete: https://www.youtube.com/watch?v=U6T01c64...
Here's another on on the connectors: https://www.youtube.com/watch?v=tYSCNsx-...
Here's a video from one of our contributors @jessabethany Jessa Jones, on how to do the soldering correctly:
https://www.youtube.com/watch?v=A0OiT9e_...
Score 2
Comments:
Add more flux! ;-)
by
Add a comment
Add your answer
Martin Muskus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 72
