The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Questions View all
Why is my MacBook Air 2013 13" USB Problem
Whenever I plug a iPhone or iPad into my macbook via USB it rapidly connects and disconnects continuously until unplugged and strangely when i connect my note 4 it wont rapidly disconnect and connect but it wont charge but can transfer data the problem has been there since I bought it second hand on eBay more then a year ago. Does anyone know how to fix this ?
I have tried multiple cables and also used multiple genuine cables new and old
Add a comment
Chosen Solution
What happens when you connect your devices via a powered USB hub to the MacBook Air? Basically we want to see if the hubs power is able to sustain the load Vs your system and everything works. If it does that points to a power issue within the system.
Can you give us some back history with your system, like did you sit it down on a wet surface or drop it.
Score 2
6 Comments:
I have no history as it was a second hand dealer and also i dont have a usb hub i do have a USB Charger Doctor - In-line Voltage and Current Meter ID will that help ?
by
What does it show for each port?
by
on both USB's they fluctuate between 5.10 - 5.13 volts while nothing is connected to the adapter
and when an iphone 6+ is connected it bounceson and inbetween .7 - .47 amps on both while the phone rapidly disconnect and reconnected
by
What is the voltage while the iPhone is connected?
by
varies from 4.8 - 5
by
Show 1 more comment
Add a comment
when I connect my devices and my external via a powered USB hub to the MacBook Air a massage says that unplug the accessory using extra power to enable usb power but but for some usb flash memory it works others do not work
1 Comment:
Your first statement it implies the hub is not being powered! The hubs power supply maybe bad or the wrong one.
Your second statement implies the USB flash drive is either bad or needs to be formatted using Disk Utility.
I would also see if the given port is bad on the Mac. Its possible you have one bad port. See it the thumb drive works in the other port.
by
Add a comment
Add your answer
Josh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,689
