Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Ringer indicator won't disappear from screen
Today water was accidentally splashed on my phone. The side buttons won't work, but even worse, the picture of the bell that says "Ringer" that shows the volume indicator won't disappear. It stays on top of everything, and because it is opaque, this makes it hard to see stuff. Is the hardware irreversibly damaged, or once it dries out will the phone (hopefully) go back to normal?
Add a comment
Chosen Solution
Hi,
It would be a good idea to open the phone up and clean any visible corrosion, there is possibly corrosion on the connectors that connect the power/volume flex.
I would also clean out the headphone port. :-)
Score 2
Add a comment
Same. I had to call apple (several hours) and have them "troubleshoot" it. We tried everything. Resetting the network, factory reset. Nothing worked. So you have three options.
1) mail it in (2-5 business days little/no cost)
2) express (1 business day 29$ fee plus a hold on the retail value of the phone mine was estimated 658.01 for a 6s)
3) set an apt at an apple store (no cost) they fix it or give a replacement unless there is water damage
If there is water damage you're screwed because it is a 350$ charge.
How to check for water damage:
1) look in head phone port, power port, and SD card for a shiny red light. If you see this there is water damage.
Add a comment
A ringer logo is disturbing me today. How i can avoid it ???
Add a comment
Add your answer
Sandra will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 29,119
