Thin, light and powerful with incredible sound and Wi-Fi capabilities is what everyone needs to have on the go.
27 Questions View all
How can I fix the antena of the NIC from a laptop?
Hello,
While i tried to fix some problems of a laptop, accidentally I broke the antenna of the NIC. The wire and the gold prong just broke off. I tried to reconnect putting the wire inside the gold prong and it seems right but, after that, the WiFi Signal is too weak. How can I fix this problem? There is some way to reconnect the gold prong and the wire?
Thanks!
Score 1
Comments:
Please give us the make and model of your system.
You likely will need a replacement antenna cable. But without knowing who's system you have here I can't offer you more. Posting a good picture might be helpful as well.
by
Asus UX303L. The only way is replacement? Can´t I tin solder wire?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Sadly this is a special coaxial wire which is crimped at the factory so you can't solder it back on.
Here's an engineers product guide for them: Micro Coaxial Connectors for WiFi & Bluetooth antennas.
You might be able to get a few samples from someone and very carefully put on a new connector. Just make sure you measure the one you have so you get the correct one.
Score 3
Add a comment
Add your answer
Ramon Paris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 204
