note 4 recent apps button not lighting up or responding
recent apps button on the note 4 isnt lighting up or responding which component do i check to on the board to see whats wrong?
Check the charger port daughter board. The two touch capacitive buttons for recent apps and back are located there.
Could be water damage inside or cable rip if screen changed before.
You will probably have to take off the screen which requires you to be careful to not break the LCD. The touch capacitive buttons are between the glass and the front display frame.
do you know where to buy those parts mine was rip
5.00 at Ebay, check forthe samsung note 4 charger cable ribbon witch comes with the two touch buttons attached, replace the whole thing
Also match the model number of the phone if possible to avoid reception issues. Antenna cable connects to charger port.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,107
