The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1427 Questions View all
Can I Fix The Lock Button on 5c Without Replacing the Cable?
Hello
I am posting to ask if its possible to fix an iphone 5c lock button that still clicks, but is unresponsive to the phone... yet sometimes the phone asks to be powered off.
Does this mean
A) I need to replace the ribbon flex cable internally?
B) I can wedge a conductive/non-conductive piece somewhere to fix it?
C) Just the button needs to be replaced?
D) Maybe something needs cleaning?
Any help is greatly appreciated. Thanks.
Comments:
I replaced the button on its own and it is now working okay. will update if any issues
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Try opening and cleaning the cable and connector, if that doesn't work try a new cable, if still no try a new button, if still no, it's a logic board problem....
Score 1
Add a comment
When the power button is disconnected does the phone still ask to be powered off etc? If yes then it's not a cable issue.
If the phone asks to be powered off with the button reconnected you will need to replace the button/flex.
I hope this helps
Score 1
Add a comment
Add your answer
ZsTech will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 66
