The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
664 Questions View all
Why wont my playstation 3 work?
OK so when I turn it on the green light will work then it just shut off and none of the lights work,but if I press the button again the red light will come on and if you press it again then the process starts over. What do I do?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
The most common cause is overheating, clear the air ports and turn off the system using the power switch in the rear. Make sure that you have adequate air flow around your PS3. Reboot your system after allowing it to cool. The other common cause is a cold soldier joint on the system board.
Score 1
Add a comment
Add your answer
lewis hively will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 48
