The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
281 Questions View all
Why is water leaking out of the hot water inlet?
I will explain by pointing out that the machine has 2 inlets - one for cold water and the other hot water. I have the cold water hose pipe fitted and not the hot water. When a cycle is started and water starts flowing through the cold water inlet at various points during this process a back flow of water through the hot water inlet is observed and hence by the ned of the wash cycle there is water in the floor.
Thank you so much for your speedy response. I have done exactly what you have advised and it's worked perfectly.
Add a comment
1 Answer
Chosen Solution
Either hook the hose up or put a plug in it. It may be siphoning. It is meant to be a closed system.
Score 3
Add a comment
Add your answer
Stephen Mulira will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 128
