Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Questions View all
How can I fix this screen? Vertical color lines.
Hello,
I'm looking for a way to fix this macbook's screen.
The only way to use is with a mini-dvi to VGA adapter with an external display.
If somebody can link to compatible screen i can buy (cheap of course :)
Thanks a lot
Add a comment
1 Answer
Most Helpful Answer
You'll need to replace the complete lid assembly. Here's the IFIXIT guide you'll need to follow: MacBook Air 13" Mid 2011 Display Assembly Replacement and here is the needed part: MacBook Air 13" (Late 2010/Mid 2011) Display Assembly - Apple P/N 661-5732.
You may want to look on eBay you might find a used one there which would be the cheapest. Just be careful! make sure you can return it and get your money back if it has any problems.
MacBook Air 13" (Late 2010-Mid 2011) Display Assembly Image
Product
$399.99
Score 1
2 Comments:
Why not just replace the LCD?
by
While it could be done you end up marring things up and often chip the cover glass. I've also found the diffuser sheets can get messed up too. The Air's and Retina systems are hard to replace the LCD panels alone.
by
Add a comment
Add your answer
SDGHZ will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,663
