In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
46 Questions View all
2005 Corolla CE: How to fix a refrigerant leak in the ac?
I've put in a can of refrigerant and it leaked out in 2 hours. Any help would be appreciated thanks
Add a comment
Chosen Solution
This may help
https://www.youtube.com/watch?v=Yyf30wSt...
Score 2
Add a comment
Most Helpful Answer
Logan Winward you obviously must find the leak first. So in order to discover where your refrigerant leak is , add UV dye to your air conditioning system and enough refrigerant to ensure the compressor turns on. Stat your vehicle and turn the AC on, the use an UV light to determine where it leaks. Something along this line. Let us know what you find.
Score 3
Comments:
The guy said I need special glasses to see the dye. Will just a uv light work?
by
You will see it with the UV light
by
Well it's more clear with glasses, those are yellow and you see the leak better, you need colored liquid. My dad is an air conditioning specialist and uses special liquid to find the leak in combination with the glasses and UV light.
by
Add a comment
Add your answer
Logan Winward will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 76
All Time: 882
