Briggs & Stratton 190cc Model 120000 Quantum 675 Series Lawn Mower Engine. Released February 2011. For Toro 6.75 ft-lb torque Lawn Mower.
28 Questions View all
Can see no gas filter in line. filter in gas tank?
in line shows no gas filter. filter in tank? gas cap shows no vent hole.
Add a comment
Chosen Solution
fuel filter is optional. Here is the maintenance manual. See page 6 features and control letter N
7065.pdf
Score 1
Comments:
There is no fuel filter at all? No vented gas cap
by
Add a comment
Ive had issues with my Briggs which had no filter.
I had to keep remving the crab and cleaning the jets.
Finally I just cut the fuel line and put one in.
It works fine now...
If I where you Id go get a cheap inline filter
then take off the carb and REALLY clean it.
Use small wire to run through the tiny jets and lots of carb cleaner
last NEVER use ethonol gas in it.
I go to my local small plane airport and buy AVGAS which is regular unleaded HIGHER octain
with NO ethonol.
Its cheaper to buy it this way then in the quarts in brand names like TRUE GAS etc
good luck
Add a comment
Add your answer
martin margolis will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 163
All Time: 4,288
