Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
MBP won't boot if LCD cable is connected?
Macbook Pro won't boot if the LCD cable is connected. However, it the cable is disconnected and the laptop is connected to an external monitor, it boots up just fine and I can see the OS. Anyone have any ideas? Tried the SMC reset and PVRAM already. Thanks for suggestions.
2 Comments
Should also add, system is running El Capitan
by
No water damage. I might just try removing the whole top half and testing the top half from a working 2010 macbook pro. It almost seems like less work than getting to the cable by removing the glass.
by
Add a comment
Most Helpful Answer
Check the LDVS cable for bent pins or corrosion. Any water damage or falls? What is the history of the problem?
Score 3
Add a comment
Also check that the plastic pull tab attached to the LVDS cable is not damaged: it prevents shortcuts between LVDS connector pins.
MacBook Pro 13" Unibody Mid 2009 Display Replacement
Add a comment
Add your answer
Shane K will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 101
