Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
My screen has color lines across and screen is cracked. Help?
Hello, I dropped my iPhone 6 and the screen was cracked. It worked just fine for a few months with the crack in it. One day I was using it and the screen went black but had this different color lines going across it. It was still working though because it would vibrate when I had a call or text. I don't want to waste money or time but, I don't know the best way to fix my problem. Someone please help ????
Add a comment
1 Answer
Chosen Solution
At the very least, you will need to replace the front LCD and digitizer. It also sounds like the connection between the main board and screen has been damaged as well. If you are not comfortable opening it up yourself, I would recommend taking it in to either the Genius Bar or a local repair shop that you trust. Do you still have Apple Care?
Score 1
2 Comments:
I do not have apple care. I will try to take it to the local repair place. I wanted to make sure that's what needed to be done or if I should do it myself. Thank you for your help!
by
Happy to help! :)
by
Add a comment
Add your answer
Miranda Johnson will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 9
All Time: 385
