Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 Questions View all
Vizio model #E420iAO Tv won't turn on
The power button will only lights the power light on the tv for a few seconds then it goes out.
Score 1
1 Comment
@arth take a look at your power board. Check the capacitors and the fuses with a multimeter. Post some images of your boards with your question so that we can see what you see. Use this guide Adding images to an existing question for that.
by
Add a comment
1 Answer
Chosen Solution
@arth sounds like a bad power board. Could be as simple as bad capacitors. You also want to go ahead and check this video to see if you have the proper voltages. Also check on here since the power board should be similar.
Score 3
Add a comment
Add your answer
Art Hickman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 13,840
