How do I replace the hard drive?
I ran a smart check on the laptop and it failed, does anyone know how to replace the hard drive?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
If you look on the bottom of the laptop, it will likely have a cover that can be removed. You are looking for a cover with a few screw holes in it and maybe a logo of 3 discs indicating a hard drive. Once you remove that the hard drive should be right below it. Be careful when removing the hard drive as most are installed on a sensitive port which if bent too far will break and will need some serious repair to fix.
Once you replace the hard drive you will need to reinstall windows (or your preferred OS) from scratch.
Score 1
Add a comment
Hello Jack,
Here is a step by step removal and replacement of a hard drive from www.hp.com website.
http://h20564.www2.hp.com/hpsc/doc/publi...
Jim
Score 1
Add a comment
Add your answer
jackchill will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 76
All Time: 1,709
