The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
3824 Questions View all
Display doesn't work after optical drive replacement. Any ideas?
Hey there,
after changing the optical drive for my old macbook core 2 duo, i booted but the screen shows only black. the macbook seems to boot normally, i can control it with the keyboard (switch off and some easy key combinations).
with the dimmer on f2 i can lighten up the black a bit, so there's a difference in the screen compared to when the macbook is switched off.
is it possible that i've damaged the screen cable? a inverter problem, maybe the RAM? or the logic board? (i hope not ;) )
at the moment i unfortunately don't have the opportunity to connect an external screen would that be helpfull?
I would be glad if someone can help me!!
all the best,
stephan
Comments:
an external display is working with no problems, i've resetted the p ram and ram
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Recheck your cables--you may have loosened the cables to the LCD when you were changing the optical drive.
Score 2
Comments:
+ My thoughts exactly.
by
+ agreed but hook up to that external monitor ASAP
by
thx i'll check it!
by
Add a comment
thx a lot, i've loosened the display cable, you were right!
Add a comment
Add your answer
stephan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 616
