Repair guides for the MacBook.
3783 Questions View all
Display doesn't work after optical drive replacement. Any ideas?
Hey there,
after changing the optical drive for my old macbook core 2 duo, i booted but the screen shows only black. the macbook seems to boot normally, i can control it with the keyboard (switch off and some easy key combinations).
with the dimmer on f2 i can lighten up the black a bit, so there's a difference in the screen compared to when the macbook is switched off.
is it possible that i've damaged the screen cable? a inverter problem, maybe the RAM? or the logic board? (i hope not ;) )
at the moment i unfortunately don't have the opportunity to connect an external screen would that be helpfull?
I would be glad if someone can help me!!
all the best,
stephan
Score -1
1 Comment
an external display is working with no problems, i've resetted the p ram and ram
by
Add a comment
Chosen Solution
Recheck your cables--you may have loosened the cables to the LCD when you were changing the optical drive.
Score 2
3 Comments:
+ My thoughts exactly.
by
+ agreed but hook up to that external monitor ASAP
by
thx i'll check it!
by
Add a comment
thx a lot, i've loosened the display cable, you were right!
Add a comment
Add your answer
stephan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 624
