Not charging when plugging in the charger, but the LEDs turn on
Hi, I know it's been asked many times, I've tried all kinds of methods in restarting, no help from that.
I know its an old machine but I just bought it and the battery was working fine and it stopped after taking the battery out and putting back in, The light on the battery turns on I checked the cells they work and overall voltage at the end of the wires is 12v :)
Now I'm wondering about the resistors on the motherboard or the battery logic board that are related to the battery charging stuff. The Mac sees the battery, but says its not charging.
I only fixing this as a hobby since I'm kinda into electronics
Sorry if my english is bad, as it's not my mother tongue :-)
Thanks
7 Comments
Can you give us the fill serial number so we know what your exact model is.
by Dan
its : w8745092z5v
by hooman
Here's your systems specs: MacBook 13" 2.0 GHz Core 2 Duo White (2007)
by Dan
thank you soo much but this isnt the answer im looking for :D
by hooman
Maybe a reset of the SMC, might help to fix this issue. My MacBook Pro 17ยจ A1229 did suffer from an issue, no entirely similar (The MacBook could see the battery, but the indicator on the chargers cable did not light up when plugged in. I tested on another old Mac (A1181) and the indicator on the cable lit up immediately. Did a reset of the SMC on A1229 and the problem was solved.
by Claus Hopstock
Show 2 more comments
