The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
162 Questions View all
Are N3DSxl ribbon cables ordered, and facing in the right way?
Hi guys,
In my picture you can see 2 ribbon connectors on the motherboard in the back... One has a black lever and one has a white lever...
Which way should the gold pins be facing?
I purchased this unit partially disassembled and cannot find clear images of this part.
http://imgur.com/uVPG8Ax
Thanks for your time!
Score 1
Add a comment
1 Answer
I don't have a XL in front of me but I do remember the order and the way they should be facing. This order will be based off your picture and the way you have it positioned there.
The closest ribbon will be the top LCD ribbon, the gold pins should be facing you as they will be facing "away" from the PCB when reinstalled.
The middle ribbon will be the camera ribbon, the gold pins should also be facing you. When installed into the PCB, it will be facing "toward" the board.
The furthest ribbon is the speaker/3d slider ribbon. This one can be a bit confusing since it's bent and installed into the PCB. These pins should also be facing you before installation. When you go to install the ribbon, the ribbon is flipped over, giving it a 45° angle. When it's installed into the PCB, the pins will be facing away from the board.
It appears that all of the gold flat pins will be facing you when passed through the hinge and I also guess it doesn't matter if the speaker and camera ribbons are flipped with each other, it just may make installation a bit trickier. Make sure that your top LCD ribbon is the closest to you. I generally find it easier to install the ribbons in this order: Camera, Speakers, then top LCD.
Note, this is based off the N3DS XL, not the LL model (which has the right analog stick nub). I hope this helps answer your question
Add a comment
Add your answer
ultimaweaponx will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 150
