Released March 2006, identified by model D620 on the keyboard bezel.
39 Questions View all
starts but stops by login, fan is not running
it starts but by the time it gets to windows login screen it shuts off.the fan doesnt seem to come on,battery is fine,is it shuting down due to it getting hot or is there a safety switch of some kind
Score 1
Add a comment
Chosen Solution
Hi, I am providing you with a link to Dell Support in the hopes they can help you. I would start in the left column under product support first. Good luck.
http://support.dell.com/support/index.as...
Score 3
1 Comment:
Add a comment
Remove the keyboard, turn on the laptop.
Touch the heat sink while the laptop is turning on.
If it's getting very hot but the cooling fan doesn't spin, try replacing the fan.
How to remove keyboard from Dell Latitude D620 laptop
Score 2
1 Comment:
Add a comment
1st thing to do is check if laptop fan and fins are clogged up with dust which are preventing it from spinning, then look at above suggestions
Score 2
Add a comment
had this a few times myself. make sure the fan connector did not come out of it's socket and that the socket itself is sitting flush and that both pins are making their way through the socket and into the fan connector.
common issue with the D series.
Add a comment
Hi,
This is definitely a overheating problem. try using laptop ventilation stand to save your laptop from getting over heated.
Good luck.
Add a comment
Add your answer
cary clague will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 6,087
