Hedge trimmer lower blade is getting of the eccentric block
Hello,
have the Poulan Pro PP6000H hedge trimmer attachment for some time.
Lately I noticed it is not cutting as it used to cut.
checking it I found that the blades are not timed and so from time to time almost move together instead of opposite directions.
I opened the unit and found out that the lower blade is getting off the eccentric block. I tried several times to put it back, assembled it but still after running for a minute or two correctly, it happened again.
Any idea on how to fix it?
thanks in advance.
Add a comment
1 Answer
Chosen Solution
Others have had the same issue with this device. I believe it is a design defect. See if you can get an answer directly from them here: http://www.poulanpro.com/customer-suppor...
Score 3
Add a comment
Add your answer
David Young will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 88
