Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
183 Questions View all
What is this part and where can I get a replacement?
Hi, I was removing the power button because I needed to reshape the corner so the button wasn't getting stuck. All went well but when I was lifting the top mental cover this little flat cable came detached so and was fiddly to get back on so i removed it thinking I'll attach the other side first and the connector got stuck on the board.
I am desperate to find a replacement but have searched the web and cant find 1. I have attached images of the cable and it where it came from. It was attached under the metal bit. You see the 2 screws on the right it was attached on the bottom side of that.
Please help! :)
Add a comment
1 Answer
Chosen Solution
This is one of the antenna bridging cables.
However I'm not sure if they'll ship to outside of China.
Score 3
Thank you very much, I will see if I can source 1 from the UK. Much appreciated
Add a comment
Add your answer
Mike11Griff will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 55
